Originally Posted by Ecky
...but that power isn't lost. It's stored in the air, and transferred back to the piston after TDC...
The first thing that came to my mind the first time I read this thread... which goes along with your statement Ecky, was of an engine I had seen some time ago that uses waste exhaust gasses and transfers that energy into a separate piston, as a secondary stage of sorts and removes extra power from that stored energy and then dumps it into the turbo... And it has some impressive performance #s... I finally found the site...
It's called a 5 stroke engine.
dfelddt91 if you can do this to your the VW engine, then that would be awesome!
