Old 09-05-2016, 05:24 AM   #5 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Volumetric efficiency increases the more air you can get in to the cylinder, so yes, forced induction increases volumetric efficiency.
Unfortunately, to keep combustion chamber temps down and prevent detonation, gasoline engines usually pump extra fuel in that goes unburnt. The only real way (that I am aware of) to prevent the need for this is to inject the fuel immediately before it's to be ignited (direct injection). So, yes, some modern engines can be turbocharged and have higher compression ratios and are thus can be more efficient.
