Old 09-06-2016, 11:26 AM   #71 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Originally Posted by cosmick View Post
So much to comment on there. The Prius is a lousy reference because it's 1.5L is an old design that was relatively inefficient even when new.
How so? The Prius, and the scads of other cars that use late-valve-closing, simulated-Atkinson cycle, are not actually Atkinson cycle engines (four strokes in one crankshaft revolution) or Miller cycle engines (which use a supercharger), and function on exactly the same principle as the Hot Rod article engine you're searching for. Someone above asked why this technology didn't "go anywhere"--the answer is, it did. It is even used in high-performance cars today.
Also, the 1NZ-FXE was a clean-sheet design in the mid-90s, and efficient enough that Toyota still uses it in the current Prius C.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
