Old 09-08-2016, 09:03 PM   #7 (permalink)
oil pan 4
I run 0.018 inch top ring gaps and 0.014 inch 2nd ring gaps on my diesel which uses 22:1 compression and will run 5 to 6 PSI of boost sustained for hours on end. I think 0.024 is way on the safe side.
The cylinder bore diameters of both are with in less than 1/4 inch of each other.
