Thread: GM's eAssist...
Old 09-09-2016, 03:11 AM   #9 (permalink)
oil pan 4
I was running some supercharger calculations for diesel place for a guy using a super charger. He was putting about 40 horsepower through a 6 rib serp belt.
The valve cover is not a load bearing structure unless you have fabricated valve cover. If they are die cast aluminum then there is little chance anyone will be able to weld anything to it and not have it crack immediately.
