Thread
1970's "30mpg" V8 cams, big car, w/14:1 CR on 87oct
09-11-2016, 08:02 PM
77
permalink
cosmick
Experienced UAW Mechanic
Originally Posted by
Vman455
How so? The Prius,
and the scads of other cars that use late-valve-closing, simulated-Atkinson cycle
, are not actually Atkinson cycle engines (four strokes in one crankshaft revolution) or Miller cycle engines (
which use a supercharger
), and function on exactly the same principle as the Hot Rod article engine you're searching for. Someone above asked why this technology didn't "go anywhere"--the answer is, it
did
It is even used in high-performance cars today.
Also, the 1NZ-FXE was a clean-sheet design in the mid-90s, and efficient enough that Toyota still uses it in the current Prius C.
Today's most efficient new engine has neither of those.
cosmick
View Public Profile
Send a private message to cosmick
Find More Posts by cosmick
