Old 09-11-2016, 09:10 PM   #28 (permalink)
cosmick
Experienced UAW Mechanic
Originally Posted by serialk11r View Post
Well see that opens up maybe too many doors haha, because you can use stuff that isn't really mass produced yet. For example I would want an electrically assisted turbo, which only F1 cars use, or a CVT drive turbo.
My ideal would be 4 cylinders, 86mm stroke or shorter so it can get near 9000rpm, using the lightest/smallest block that can be bored out to around 1.6L, with switchable cam profiles e.g. VTEC so it can have an Atkinson cycle mode. Add a mild hybrid system, and if the car is a little heavier add a small amount of boost, no more than 0.4 bar for minimal lag.
The boost pressure has little to do with lag. Being a 1.6L you want all the boost pressure the engine can hold. Choose accordingly. GM's 2.0L Ecotec can be built to 1200 horsepower.
