Old 09-12-2016, 12:09 AM   #24 (permalink)
Andrewhans
Studying Brick economics
Andrewhans's Avatar
Tahoe - '04 Chevrolet Tahoe LT
90 day: 12.27 mpg (US)
Originally Posted by cosmick View Post
You should actually have less aero drag than my 06, didn't read which engine you have, nor axle ratio, nor tire size, but with a 4.8 and 3.73s you should see 23 if you were 2wd, and you may want to try removing the front shafts until winter. With a 5.3 a 3.42 gear should also do 23.
I think the AWD is costing me a lot but I have no way to confirm it. I can't remove the front shafts because the transfer case has a viscous coupling with a 40/60 split to it. Without the front connected the transfer case would burn up within a mile or two. I have seriously thought about buying a used 4x4 transfer case, installing it and just making it stay in 2wd.
5.3 engine, 3.73 front and rear, 275/55/20 tires. The wheels are 20x9's which is a factory tire/wheel combo on newer GMC Sierra's.
