Old 09-12-2016, 12:27 PM   #15 (permalink)
freebeard
It was a qualifying question. So Okay.
http://ecomodder.com/forum/showthrea...ail-33283.html
The Morelli fluid tail thread shows the Mooncraft Prius body kit, which is only 3/4 complete by theory.
versus
Then the trailing edge can be treated to plasma actuators. The site search function is borked right now, but there is a member here testing these for truck bodies.*
Spot painting metallics is problematic. You should repaint to the panel edge.
Or just do the top in white PlastiDip and put a shark mouth all across the front.
Edit: *There's enough to get you started here:
http://slideplayer.com/slide/8653868/
