Old 09-14-2016, 11:03 PM   #4 (permalink)
redpoint5
90 day: 38.47 mpg (US)
It depends on if it's the upstream or downstream O2 sensor. The car uses the upstream (before catalytic converter) to adjust air / fuel mixture, but the downstream (after cat) sensor just measures the function of the cat. The upstream sensor is the one that matters.
You can buy aftermarket sensors for much less and install it yourself.
