09-14-2016, 11:32 PM
#37 (permalink)
マット
Originally Posted by Xringer
That charge controller looks pretty nice.. In section 4.1.1 How MPPT Works, it describes how regular MPPT works and then explains how "TrakMax’s MPPT technology operates in a very different fashion".. I didn't actually read the manual I'll probably read it when I get it in my hand
It's pretty cool the way the unit can use your panels in series or parallel, and still pull the max-power-point power out of them..
I was gonna do series just because of the wires plus I didn't want to buy the connectors for parallel, but hey an extra plus!
Series has the advantage of lower current (higher voltage) and less amps means you can use smaller wires from the panels to the controller.. Easier to install, and cheaper too..
Matt
