Originally Posted by Vman455
If you Plasti-dip the roof white, you could peel it off in the winter when you don't mind the cabin getting a little warmer.
i know a lot of hypermilers don't care about looks, but plastidip can sometimes stain on hoods and roofs. Also if it gets excessive heat (like your hood) it can be a pain in the ass to remove unless you lay down about a dozen coats. Last time i plastidipped my car I had to use a power washer to remove some of the dip on my hood and roof.
