Thread: 2006 Aveo build
Old 09-15-2016, 08:20 PM   #3 (permalink)
freebeard
Welcome to Ecomodder.
What's the use case — single seat commuter?
That interior is very similar to mine, except that I made a two-piece plywood deck to level out the floor. My car has more of a center tunnel, so there is a compartment inside the right-hand door for road flares and a 4-way lug wrench. In addition to being a utility van, it has a second function as a one-person camper, so it has welding-rod curtain rods, a Koolatron fridge and an extra 12v socket w/ 5v USB adapter. And compass.
If you snap in a 3/4 tonneau cover would it muffle the sound?
Between the 14" and 16" wheels look at weight (important in stop and go) and diameter (determines final gearing). You might do well just adding a flat wheel disk or four.
