Old 09-15-2016, 10:32 PM   #6 (permalink)
Jonny
Originally Posted by California98Civic View Post
...and one more question: why do you suspect the MAP sensor? (I had a problem I interpreted as the Map once, and it turned out to be the ignition coil.) So what's the source of the suspicion?
Well I've replaced the "slightly" expensive wideband O2, and I can't think of anything else.
