Originally Posted by iveyjh
Cam degree per tooth is 9 degrees but you have to consider that the crankshaft goes around twice for every one rotation of the cam shaft which translates to 18 crank degrees instead of 9 and advance/retard is based on crank degrees. Hope that helps.
Yep, and 18 degrees is a metric shizload of change. I would be careful about valves and pistons getting intimate in unintended ways. Have you checked the clearnace?
Simon
