Originally Posted by redpoint5
Whew, just a fuse. Thought it was good because I checked the rear light fuse, but the one that was blown said brake on it. Not sure if that is the fuse for the brake system, or for the brake lights. I'll check for shorts in the trailer tomorrow.
The Traction Control light is still illuminated, so the car isn't entirely happy yet.
I think you will find that after a few successful start-stop cycles of the hybrid system the light may go off but a code will still be registered with freeze frame data. I bought a cheap Chinese cable with a "copy" of tech stream from eBay to read and reset these things. Cost about $40 if I recall. I recommend you do the same. It also allows you to see battery voltages and lots more interesting stuff.
Simon
