Originally Posted by ricemodder
That sounds interesting, what is that? I'm working on something that is possibly similar. Built in resolver?
It's almost a resolver but not quite:
http://www.rls.si/fileuploader/downl...ic_encoder.pdf
That's an example of the one built in to my motor (DLC-28 e.g. Motenergy ME1302). It only takes V_dd, GND, and Shied (always optional, amirite?) and outputs 2 lines: sinusoids offset by 90 degrees with an aplitude of 3/5*V_dd.
In theory, it should be as simple as probing the pins with an ADC read (they output analog voltage) and doing some reverse trig to see where we are. It's a good middle ground in the whole encoder/resolver thing--the tight resolution of a resolver with some of the simplicity of an encoder.
