Old 09-16-2016, 10:11 PM   #48 (permalink)
LittleBlackDuck
LittleBlackDuck's Avatar
CT - '11 Lexus CT200h Luxury
Originally Posted by MPGeo View Post
THANKS EVERYONE!!! Complete brain-fart on my part...
I knew it was 2:1 ratio, but complettly forgott (obviously) to think throuhg how that relationship would affect the event timing... That's what happens when you start improvising@ 2am...
I tried.... Now to figure how to accurately meassure 5degrees and drill/slot a new hole
Pretty easy. Buy a degree wheel, bolt it onto the crank and follow any number of videos on how to degree a cam. Measure what the stock one's timing is then slot and play from there. A cheap way is to search google images for a degree wheel, print, glue onto a bit of tin or card and play...
You can also buy offset dowels and bushings - once you know the amounts talk to your local hotrod engine builder.
Simon
The Following User Says Thank You to LittleBlackDuck For This Useful Post:
MPGeo (09-17-2016)
