Light throttle acceleration, coasting as much as I can, staying at the speed limit,.
My tire pressure is at 34psi, because the tires I have on there are worn out. (I am at Oregons minimum depth or the wear bar.)
I will be looking at 175/65r14 Michelin Defenders, from tire rack, for my replacement tires.
Thank you,
Jared
