Old 09-17-2016, 08:50 PM   #5 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Originally Posted by Jared View Post
Light throttle acceleration, coasting as much as I can, staying at the speed limit,.
My tire pressure is at 34psi, because the tires I have on there are worn out. (I am at Oregons minimum depth or the wear bar.)
I will be looking at 175/65r14 Michelin Defenders, from tire rack, for my replacement tires.
Thank you,
Jared
Try more throttle, just keep RPM down. I use at least half throttle and upshift around 2000 RPM. As long as the tires aren't cracking, they should handle more pressure. I run my worn tires at around 55 PSI.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
Jared (09-17-2016)
