Old 09-17-2016, 09:23 PM   #144 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
Originally Posted by Isaac Zackary View Post
I completely understand that. But what if you could run an AFR of 25:1, 50:1, or 100:1 or leaner in a gasoline engine and still get complete combustion. You could practically eliminate the throttle valve and eliminate pumping losses through it. Slight amounts of hydrogen have the potential to aid spark ignited combustion to the point that ultra lean AFRs could be obtained and still be running a homogenous air/fuel mixture.
If you understand that you can't get free hydrogen from water you are way ahead of most HHO proponents.
It sounds to me like you looking to do something similar to HCCI. Lots of engine / automotive companies are working on that technology but none to date have been able to create a working engine that can run at various loads / RPM. Controlling the ignition process has proven to be very difficult.
The Following User Says Thank You to JSH For This Useful Post:
Isaac Zackary (09-18-2016)
