Thread: 2006 Aveo build
Old 09-19-2016, 07:41 PM   #35 (permalink)
freebeard
I like nice wheels too.
– Center Bore: 56.6 mm
– Lug Size: M12 x 1.5
– Wheel Fasteners: Lug nuts
– Tire: 155/80R13
– Rim: 5Jx13 ET45
– PCD: 4x100
Chevrolet Aveo 2005 - Wheel & Tire Sizes, PCD, Offset and Rims specs - Wheel-Size.com
– Center Bore: 66.7 mm
– Lug Size: M14 x 1.25
– Wheel Fasteners: Lug bolts
– Tire:155/70R19
– Rim:5Jx19 ET43
– PCD:5x112
BMW i3 2013 - Wheel & Tire Sizes, PCD, Offset and Rims specs - Wheel-Size.com
So, aside from wheel well clearance, the nut to crack is 4(studs)x100(mm) vs 5(studs)x112(mm). It's like putting Porsche wheels on a VW, you can use adapters or get blank drums and rotors and have them drilled for the correct pattern. But get the rims and first set of tires from a wrecking yard.
Personally though, I feel my car performs much better in snow/rain/dry conditions than it did with the poker chips it came with stock. But maybe that's the placebo effect, mind over matter.
There's rim vs tread width, rubber compound, tread pattern, shoulder radius, inflation pressure. Different tires have different uses — street/track/off road.
