Old 09-21-2016, 12:21 AM   #16 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Originally Posted by elhigh View Post
Being a sedan, your aero at the back isn't great and difficult to change without limiting access to the trunk. You may want to spend most of your time making the rest of the car as slippery as possible before you get into a partial or full kammback that will work with your trunk lid.
Instrumentation is your friend, except it may not be your friend. A 91 Civic will have an OBD 1 port, and all the aftermarket instrumentation devices use OBDII, which has been the standard since '96 in the US. There are adapters available to convert an OBD1 port to use an OBDII scanner, but I don't know whether that will permit the instrumentation devices to talk to your system. If it does, I strongly recommend you go for it - more information makes you a better driver.
I'm seeing adapters on Amazon for $20 and less, and the OBDII-to-phone transmitter I got was about $25 or less. Torque Pro is about $5 and opens up a RAFT of instant readings, average readings etc. Again, I don't know how well Torque Pro, which is geared toward OBDII, will function with OBD1. As they say, your mileage may vary.
The sedan's Cd is actually worse than the Wagon! 0.38 vs 0.35. But the taller Wagon has more frontal area.
I don't think these old Civics have any diagnostic port. Trouble codes are read by counting blinks of an LED on the ECU.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
