As for tire grip; the sideways grip seems to improve with high pressure due to less deformation. High tire pressure may help avoid danger, even if braking distance suffers (which I doubt, actually).
One thing that goes beyond doubt is that both braking and handling improve when you get top tier tires.
All cars and bikes I bought secondhand had cheap tires on them, all of them improved dramatically when fitted with the right stuff.
I air up my tires (moderately, even) with a clear conscience.
 lifetime FE over 0.17 Gmeter or 0.1 Mmile.
