Old 09-23-2016, 02:33 AM   #26 (permalink)
LittleBlackDuck
LittleBlackDuck's Avatar
CT - '11 Lexus CT200h Luxury
Originally Posted by RedDevil View Post
As for tire grip; the sideways grip seems to improve with high pressure due to less deformation. High tire pressure may help avoid danger, even if braking distance suffers (which I doubt, actually).
One thing that goes beyond doubt is that both braking and handling improve when you get top tier tires.
All cars and bikes I bought secondhand had cheap tires on them, all of them improved dramatically when fitted with the right stuff.
I air up my tires (moderately, even) with a clear conscience.
RedDevil, agreed totally and there is a happy medium that delivers improved economy, better handling and also reduced braking distances. I do not believe that it is 25% in excess of the maximum sidewall pressure...
I also run my tyres at an increased pressure, generally about 20-25% above the manufacturer's recommended. I also run a tyre pressure monitoring system to alert me of a puncture and to optimise economy. These can be bought aftermarket for around $80 and will more than pay for themselves if you avoid one puncture being run flat at highway speed.
Simon
The Following User Says Thank You to LittleBlackDuck For This Useful Post:
RedDevil (09-23-2016)
