Old 09-24-2016, 01:27 AM   #114 (permalink)
jamesqf
Originally Posted by Astro View Post
By comparison, EV charging is much less stressful. Plug it in, lock the doors and go and have a coffee, maybe make a few phone calls, go to the toilet.
Even at the worse, doing those things won't take more than 15 minutes or so. What do you do with the other several hours it's going to take to recharge?
It's silence, both inside the cabin and out.
Even with IC engines today, it's easily possible to have engine noise be less than tire & wind noise at cruise. I doubt this is much of a plus for a large segment of the car-buying public, else why would manufacturers make most of their vehicles much louder than necessary (diesel pickups, for instance)? Even then there's a large market for aftermarket mufflers & other exhaust components that are much louder than stock.
Low ongoing costs, servicing, maintenance, etc.
IC related maintenance is already trivially low on well-designed modern cars: oil & filter change around 10K miles, spark plugs at 100K. The non-engine parts of an EV - tires & suspension, A/C. wipers, &c - will need just as much maintenance as an IC-engined car. Maybe more, if you burn a lot of rubber in ludicrous mode :-)
