Scangauge in Toyota Echo, Xgauge problem.
I'm wondering if anyone with a early Toyota echo is using Xgauges. What protocol are you using? Mine is a 2000. When I set the mode to auto, it switched to KWPS protocol. The regular gauges on the Scangauge all work fine. I'm trying to set up fuel trim and O2 sensor gauges so I can diagnose a error code, but when I used the KWP formulas from the scangauge site the gauges don't report. I know they can report because they work with the Torque app and a ELM adapter.
Almost all my driving is done 1-5 miles at a time.
Best short trip: 2.4 l/100 km, 3.9 km
