You can debate and compare tread patterns and rubber compounds all you want, but the real action is in the gross geometry. The advantage goes to tall and narrow:
http://ecomodder.com/forum/showthrea...-25208-13.html
TL;DR
If you have a 5x112 or 5x120 BCP and 27+ inch diameter it's a fairly straightforward fitting. These are as new as the BMW i3. You can get M
oon disks in that diameter, too.
