Old 10-01-2016, 06:46 PM   #10 (permalink)
Jonny
Originally Posted by Jared View Post
Routine maintinance is always something to keep in mind. Cap, rotor, plugs, wires, throttle body cleaning, injector cleaning. Air filter, tranny fluid (low?), coolant level.
Also is there any other numbers or letters after the d15? If not then you might have a jspec motor swap.
I know this is quite a delayed reply, but yes, it's a JDM motor. Dude who owned it before me put it in for some reason (at the time, I believe it was MUCH cheaper). From what I can tell, there is absolutely no difference between the D15B and D15Z1 aside from the head code, which obviously doesn't matter aside from the obvious things (ECU, etc). I perform all regular maintenance.
Car is a KL variant, so passed smog just fine for years with both engines apparently.
Now I'm burning oil. Worried about compression, but hoping it's something simple like PCV valve.
