Thread: 2001 Insight
Old 10-03-2016, 12:35 AM   #41 (permalink)
Natalya
Engine-Off-Coast
Natalya's Avatar
Red 2000 Insight (2017 through 2019) - '00 Honda Insight 5MT
90 day: 64.72 mpg (US)
Red 2000 Lithium Insight (2020) - '00 Honda Insight LTO
90 day: 71.76 mpg (US)
Warm Air Intake
I made it out of a 6" adjustable HVAC connector and a lot of reflective aluminum HVAC tape. Here you can see that I cut the front-of-vehicle side in half so that during installation I could open it and get it around the catalytic converter.
This is the complete assembly before installation. I didn't know the positioning of the upper cat sensor, so its hole is not drilled here. I ended up drilling that hole after installing the rest of it. The duct is 3" diameter. I should probably replace it with something more sturdy, this is a really crispy mod.
Here's how it fit on the cat. Not a perfect seal, not even close, but better than the shield it had before. The old shield was something I made out of some garbage aluminum flashing metal. The OEM heat shield was gone when I bought the car.
All hooked up. I'm wondering if I'm causing any airflow restrictions and losing power because of this. I guess I need to do A-B-A testing. I did, for like a second, see 130°F on my ScanGauge for Intake Air, which is the hottest I've ever seen.
The Following User Says Thank You to Natalya For This Useful Post:
MetroMPG (12-07-2016)
