Did you check your fuel pressure? Mine was out of spec but still running, but poorly.
I checked the pressure and it was 29psi and 36psi.
After new pump the pressures were 35, 45psi
Runs awesome now. No hesitation, mpg up, more power, better idle. All fixed with new pump.
