Old 10-06-2016, 12:13 AM   #15 (permalink)
stovie
the green machine :P - '97 Jeep Grand Cherokee ZJ
90 day: 20.92 mpg (US)
Thee s10 - '00 Chevy S10
90 day: 24.27 mpg (US)
Freedom - '05 Kawasaki Ninja 250EX
90 day: 75.55 mpg (US)
LE Focus - '05 Ford Focus
Not possible, with most motherboards. They also need 5v and 3.3v, as well as some negative rails. Also, 12.6v is asking for trouble, and if you tried to use a car's charging voltage of 14.2v, you'd fry it instantly.
EDIT: You really need a DC-DC converter, or a DC-AC and use the normal power plug.
Looking into it you can get a resister setup to get the 5v and 3.3v from the 12v. At which point you'd need to find something to only supply 12v to the system!! If you could wire a car battery to the motherboard and used a 25 amp alternator you could possibly produce enough power to run it for 5 hours from one hour of peddling!!
