Old 10-06-2016, 05:47 PM   #16 (permalink)
MPGee
'07 Toyota Matrix - 36MPG
Small Red - '07 Toyota Matrix
90 day: 37.49 mpg (US)
Originally Posted by aardvarcus View Post
MPGee,
Vskid3 was correct they were stock wheels from a 2010+ Prius. My old car was a 2002 Toyota Celica. The 16" stock alloys I removed were around 21 lbs, and the 15" prius wheels were around 14 lbs. The tires were lighter too, I don't remember the specifics on those. That wheel and tire combo is still going strong on my brother in law's car, as I swapped on some other less valuable wheels and tires prior to selling.
Thanks, aardvarcus.
Hmm. It is damn frustrating to try to get wheel weights on just about anything, let alone accurate weights. I was trying to find weight info on the Prius wheels, b/c of your suggestion, and the best I can find is posts from Joe-Schmoe on different forums. I wish the mfg's would release official #s on this. So, the info I could find on my steelies, a Corolla steelie, and '05 and '10 Prius alloys, this is what I could find...
2007 Toyota Matrix steel wheels
16x6.5": 5x100, 40mm offset
9.1kg (20 lbs)
Weight from a post on matrixowners.com but the site is down right now. (Will try to add this later in an edit)
Other info: Toyota Matrix 2007 - Wheel & Tire Sizes, PCD, Offset and Rims specs - Wheel-Size.com
2007 Toyota Corolla S/LE steel wheels
15x6": 5x100, 45mm offset
7.3-7.7 kg? (16-17 lbs?)
Weight eyeballed from rather questionable sources online.
Other info: Toyota Corolla 2007 - Wheel & Tire Sizes, PCD, Offset and Rims specs - Wheel-Size.com
2005 Prius OEM alloy wheels
15x6J: 5x100, 45mm offset
6.45kg (14.2 lbs)
Sample pic: http://static.cargurus.com/images/si...873362058.jpeg
Weight from: OEM wheel weight - GreenHybrid - Hybrid Cars
Other from: Toyota Prius 2005 - Wheel & Tire Sizes, PCD, Offset and Rims specs - Wheel-Size.com
2010 Prius OEM alloy wheel
15X6J: 5X100mm PCD, 45mm offset
7.4kg (16.3 lbs)
17X7J: 5X100mm PCD, 50mm offset
11.0kg (24.3 lbs)
Sample pic: http://images.newcars.com/images/car...-Side-View.png
From: https://priuschat.com/threads/wheel-weight.64309/
