So if you look at these specs:
Zero S Electric Motorcycle - Specs || ZERO MOTORCYCLES
Zero DS Electric Motorcycle - Specs || ZERO MOTORCYCLES
The difference in range is mostly because of the tires and the front fender. I'm guestimating that with more roadish tires and a proper windscreen 15% extra range should be doable.
