Old 10-12-2016, 10:22 PM   #298 (permalink)
toccoa
Originally Posted by Bill the Engineer View Post
Partly I needed to keep things simple by using the existing Firebird core support to hold the front of the fenders and the hood latch mechanism in place. That would be impossible with the original fenders. It was also partly due to an interference between numerous Firebird and Prius parts if I didn't extend the fenders. I mentioned these in earlier threads. Prius things would have been poking out the bottom, and the Firebird headlights and grill would not have fit around the Prius framing around the cooling cores.
That being said, all the Firebird parts are bolted on, so if I decide later that I don't like the look, I can still change it again.
Bill the Engineer
Thanks for the reply. I think I do remember you writing about keeping it simple. Although, that was before you created those awesome brackets.
I didn't think about the bottom. That would be a challenge to hide and certainly not simple. Like you said though, you can always revisit that later (Firebrid v1.1).
Keep up the good work. I truly enjoy seeing this all come together.
The Following User Says Thank You to toccoa For This Useful Post:
Bill the Engineer (10-13-2016)
