Old 10-13-2016, 02:45 AM   #33 (permalink)
sameb
Rogue Engineer
Originally Posted by Baltothewolf View Post
Then you are putting a band-aid on a bigger issue. I still wouldn't run straight E85 in a car that's not set up for it. You are asking for trouble. You are stressing the entire fuel system! It's like running boost and saying 'Yea, we don't need to add extra fuel, it's fine'.
I want to remind you that I am supplying extra fuel to the cylinders by putting in bigger injectors. Everything else is stock. It is putting more stress on the fuel pump, but it doesn't seem to be causing any problems.
