Originally Posted by rmay635703
GM has put the powertrain into the 2016 Malibu hybrid and it gets class leading fe
Did not know that. Those are some impressive numbers for a car that size.
Cowmeat, it looks like the range estimate
adjusts based on your driving. What's the farthest you've gone on a single charge?
Do you mainly drive with it in L? I noticed that the one I test drove would just coast when you let off the gas in D at city speeds (which I prefer), but it would regen at freeway speeds (pretty sure both were in normal mode). This was going off the kw display the 2013+ received, not sure if or how it would show up on the 2012's displays.
