Old 10-14-2016, 01:42 AM   #10 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
From some experimenting that I have done on my Talon, lean burn defiantly helps with pumping losses but as others have said it does slow flame speed. I can run lean burn and EGR hot or cold and it gets to a point where flame speed has the final say. I'm now working on my eight proto type lean burn pre-chamber(stratified charge). This new pre-chamber I hope will increase flame speed by a hotter kernel that will reach deeper into the combustion chamber.
Then I should be able to run normal ignition advance with a fast flame speed.
Pressure Gradient Force
The Positive Side of the Number Line
