Old 10-14-2016, 04:32 AM   #570 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Thanks, but I'm not getting that at all. 2pass was a different, previous effort?
My best effort would be — suck air out of the front wheel wells [to smooth flow down the sides] and pump it mechanically into the stagnation point so the heated air energizes the airflow over the windshield. Close?
They went to CNR Radiators to get these fabricated and manufactured, and then CNR took the design and told all the other NASCAR teams about it, so they built them for the other NASCAR teams so there’s no advantage there. But we had an advantage for a race or two.
Like this.
We turned the fan blades around and put them in a cowled duct, which you’re allowed to do, and blew the air through the radiator out the front. So instead of allowing air through the radiator from the front of the car into the engine bay, we forced the air out of the engine bay, drawn through the wheel houses, and also filled in the boundary layer over the body surfaces, cutting down drag.
The problem they ran into was suspected to be belt slippage. At speeds way above those experienced by an Ecomodder. He suggested a cog belt ,similar to a blower or dry sump oil pump as a potential ****ion. He was forbidden to do further any testing by Nascar, thank you Mole.
Hope this helps
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following 2 Users Say Thank You to gumby79 For This Useful Post:
aerohead (10-15-2016), freebeard (10-14-2016)
