Old 10-14-2016, 08:15 PM   #9 (permalink)
jamesqf
Something you need to think about is that IIRC the Insight is rated to handle only 350 lbs of passenger & cargo weight. That's 2200 lbs, and you'd be going a couple of hundred pounds over that before you add the driver. You've also got fore-aft balance to consider. Best case, I think you'll need to look at suspension upgrades.
