Old 10-15-2016, 08:21 AM   #15 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Originally Posted by CappAttack View Post
I suspect the power brake booster as it has a cracked vacuum line. Going to order a replacement this coming payday.
Are you replacing the vacuum line or the booster? Hard to tell from your wording...
I'd assume it isn't getting vacuum, but I'd check/replace vacuum lines and check for vacuum at the booster and at the vacuum pump before replacing the booster itself, if you were going to.
