Old 10-15-2016, 01:01 PM   #17 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
The 2012 HCH motor is... offset 2mm? Is it unbalanced, or.. ? I guess I'd have to see it
Anyway, with all the trouble to decouple the low-powered (and I believe, not terribly efficient by modern standards?) IMA from the ICE, would it not be easier to just add a second electric motor.
The ima motor is perfectly efficient but the algorithm and mosfets driving it aren't the most efficient.
Linsight improves driver efficiency, if you can find a modern pin compatible mosfet the Ima will be no less efficient than new.
As for a second motor it's very tough, insight just doesn't have clearance for anything
