Old 10-15-2016, 04:25 PM   #22 (permalink)
cRiPpLe_rOoStEr
Originally Posted by Bicycle Bob View Post
Ideally, the exhaust valves should not release unused pressure, but we currently waste the intake pressure differential needed for that without a true Atkinson crankcase.
The only advantage that I can see in that Atkinson effect applied through a longer intake valve timing is that the mixture that goes back to the intake manifold decreases further the temperature of the subsequent intake charge.
