Old 10-18-2016, 03:29 PM   #50 (permalink)
KFM
KFM's Avatar
Terminator - '00 Honda Insight Base
Gen-1 Insights
90 day: 72.78 mpg (US)
High Voltage - '12 Chevrolet Volt
Team Volt
90 day: 108.44 mpg (US)
Originally Posted by cowmeat View Post
Electric companies charge different rates at different hours of the day so I'm charging my car at night, when the grid sees the lowest usage and they charge less per kwh
During the day at peak usage the electric is a lot more per kwh.
Also, I read somewhere that finishing the charge just as you're getting ready to use the car will keep the big battery at a proper operating temperature
Below is the rate chart at Lakeland Electric, the rates vary A LOT!. So charging the car, running the dryer, etc . . . are way cheaper late at night
Gotta add in the fuel charge for LE so it ends up being almost $.07/kWh for off-peak and $.18 for on-peak. Still, they're amazing rates. I love the Shift to Save program, but I end up paying more in taxes than the actual amount of energy used.
