What does your commute look like?
I have a commute that's practically set up like a Volt commercial. 19 miles each way, no more than 50 mph on any part of the route, all flat land with relatively few stops. Driving in "L" regens enough to give me at least 45 miles of range.
Are you using the 120 VAC EVSE ?
Not sure what that is, but I charge it at home on 120 with the stock Volt charger. I charge it from about 9:00pm to 5:00am
How many KWH is the battery on your car . The Leaf had a 24 KWH battery .
The Volt has a 16 kWh battery, but only uses a max of 9.9 kWh of it (to preserve battery life). It had 51K miles on it when I bought it
