Originally Posted by NoD~
Gumby,
I'm confused about the ride height and ground clearance. Aren't they the same chassis/body? Not sure how it could go up and be shorter.  Don't know all that much about them, though.
The Forester is the highest, the base sedan the lowest, the Outback Sport somewhere in between. The seat in the Forester also sits higher and the cabin is taller.
So a 2002 Forester has 7.5" clearance
a 2002 Impreza outback sport has 6.3"
and a 2002 WRX has 6.1"
the 2002 RS sedan is only 5.9"
The XT came out in 2004 and is a bit higher at 7.7" but think it is automatic only (never mind, only the premium versions are automatic only)
There are aftermarket lift kits that involve strut spacers and a trailing arm spacer to recenter the rear axle. There are also body lifts available. You can also add the Australian 2 speed transfer case if you really wanted. I like mine stock, I still run all season tires although I have punctured 2 of them off road. That will be my first change but 3 years later they still have tons of tread left I don't think they are ever going to wear out! I do run studded snow in the winter, those were worn more to begin with and now are about worn down on studs but still have lots of tread left.
here is all things Subaru specs
Subaru Research Site- specs, prices, options, 2017, 2016, 2015, 2014, 2013.... Outback, Legacy, Forester, XV Crosstrek, Hybrid, WRX, STI, Impreza, BRZ, Tribeca
