Old 10-18-2016, 10:29 PM   #59 (permalink)
Hank1510
Originally Posted by cowmeat View Post
Not sure what that is, but I charge it at home on 120 with the stock Volt charger. I charge it from about 9:00pm to 5:00am
An EVSE is electric vehicle supply equipment. The actual charger is in the car. The EVSE plugs into the wall to communicate and cut power quickly if something goes wrong. If you call it a charger, we all know what you're talking about.
Level 2, 240v, is actually more efficient than 120v. It uses less kWh to charge. 12 amp is more efficient than 8 amp 120v charging. I can't remember how much more efficient.
Originally Posted by ocnorb View Post
This is the best mod I've done:
Allows you to seamlessly move between 120v and 240v and use several styles of 240v outlets anytime.
I really wish I saw this before I got a level 2. I keep the stock one in the car to charge at work though.
The Following User Says Thank You to Hank1510 For This Useful Post:
cowmeat (10-19-2016)
