Old 10-20-2016, 08:25 PM   #45 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
This is why I'm looking at theas..
From:Eberspacher Hydronic II M12 12v (12kW) Heater Kit - HEATSO
But $1000 is spendy.
Many manufacturers are putting theas or part of this in vehicles. Fuel-driven heater, general description - V70 2007 - Volvo Cars Accessories
The advantages of a hydronic system is it can be plumbed to heat the oils. Self contained, isolated from engine coolant circuit. Heating can be achieved with a tube and fin trans cooler, P/S cooler for M/T and transfer case , ( dime a dozen at recking yards )aluminum foil taped to the bottom of the pan.add some foam more tape. Can be done without interfering with maintenance acces.
Found this wile looking for parts to build one from a propane Instant water heater , a set of check valves, aVw electric circulation pump. Add a remote from a set of Bling Bling leds from Autozone . And wala 15-30min from -40 to 160°f . No plug no problem. I was thinking add tubes in the oil pan and routing the exhaust from the heater, to warm the frosty oil . Till i build the oil pan I was thinkingof gust haveing the ehxsost blow out agenst the oilpan. Thoughts ? your pumping3ga of- 40 oil through your 4ga of 65°water it will take a while to warm all of the oil this is why I'll be idiling my cummins this winter wile pkuged in all the time. Last winter the stock 750w block heater wouldn't even melt the snow off the truck.
I idle till the grid heater cycle time comes down to just a pulse. In the cold, evan with plug and clear glass. Turn on the defrost turn down the temp. To put more load on the engine and warm the air around the radiator. My block off winter front is behind the A/C. So all the heat developed is concentrated on 120*2in aera of the radiator. I've put some thought into cause and effect.
What temperature can we warm mobile synthetic oil to without causing off gasing/boiling/ cokeing? VS conventional oil?
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
