Thread: The Holes!
Old 10-22-2016, 10:00 PM   #51 (permalink)
freebeard
Originally Posted by paconassa
Aerohead, care to explain that a bit more in detail?
With which cfd are you comfortable with?
I'm putting words in aeroheads mouth here, but it's probably the primitve rendering algorithms. Traditional rendering techniques hit the wall, so to speak. You can't render a sufficiently large volume at sufficiently fine resolution to produce a viable result before the heat-death of Universe.
Personally, I look forward to more advanced software based on OpenVDB. Instead of thinking outside the box, this makes the box fractal and extensible.
Edit: well that's inaccurate. Open VDB uses sparsely populated four-level binaries trees, not fractals; this means calculation is more focused more closely to the surface. And it uses bitmasking to have — in addition to pressure and velocity — for instance color (for smoke streamers) or viscosity (for raindrops and groundwater).
