Old 10-23-2016, 12:54 AM   #22 (permalink)
freebeard
Here is a body that is all bubble.
What it shows is that your pie cuts can be as triangles, diamonds or hexagons. Diamonds are good, you can score or brake a flat sheet at two different angles. That will kill the flatness right there, then make your pie cuts along the creases as required. Then trim to the outline you need.
Instead of following the body, impose your own shape onto it.
